I've located a bad heating element in my seat heaters and I'd like to see if it can be repaired or if I need to replace it. Does anyone have tips for removing the bottom seat cushion to access the heating elements?
Shawn
Shawn
Disregard, I figured it out. For anyone wondering, there are two white clips under the front edge of the seat. There is a "pin" that goes through it into the base. Pull on the pin to release the rivet. Then pry the white clip away from the base and it will pop out releasing the front edge of the seat. The back edge is just wedge in and can be slid out.
Shawn
Shawn
Shawn
Thanks for the post Shawn!
