Hi All,
I just picked up a lovely Cayenne from US and imported into Canada. For some reason Porsche seems to
not follow the standard of providing Speedos with both mph and kph (generally kph in smaller font size).
I will have to have this changed to kph to pass inspections in Canada and wonder if there is a source that
provides these kph dial faces?
She's an 04 S and I appreciate any input:)
Robert
  muckmusic said:
Hi All,
Robert
Hello Robert.
I've also imported a Porsche Boxster from the US, and I also got a cluster in MPH, but to pass the RIV inspection,
you only need to switch the Digital display from MPH to KMH, It make no difference from them if your analog
display is still show MPH but you need to have the odometer in KMH and the digital speedometer display in KMH.
For the Boxster we switch from MPH to KMH by turning and holding the clock knob, I don't know about the Cayenne
but it should be similar. Look in your Porsche manuals.
Best regards
The Cayenne is a 2004...what year is the Boxter? I'll check the manual and see if this is possible as it'll be the best news if so:)
Thanks for the reply!
Robert
  El Acura said:
  muckmusic said:
Hi All,
Robert
Hello Robert.
Best regards
Hey Bro,
I also have a 04 CS and you can do it on the digital input. Just look in your manual and it tells you how to do it (sorry it is slipping my mind)
Cheers,
Parajed
Robert
  El Acura said:
  muckmusic said:
Hi All,
Robert
Hello Robert.
Best regards
I've just tracked down the info in the manual, and it appears to be a simple task of toggling within the units/speedo
on the digital menu and selecting kph.
I will put this to practice soon and let you helpful lads know how it went.
Thanks much:)
Robert
  parajed said:
Hey Bro,
Cheers,
Parajed
Robert
  El Acura said:
  muckmusic said:
Hi All,
Robert
Hello Robert.
Best regards
BTW Parajed...did you manage to switch the daytime running lights on yourself as well? The manual doesn't seem
to touch on this, only seems to explain the 'auto' light functions.
Maybe when I get into the menus it'll make sence:)
L8R...&....TIA
Robert
Thanks much:)
Robert
  parajed said:
Hey Bro,
Cheers,
Parajed
Robert
  El Acura said:
  muckmusic said:
Hi All,
Robert
Hello Robert.
Best regards
The speedo is simple...you toogle through the menus on the little lever below the signal light, it's all in the manual. As for daytime running lights (DRL) you will need to either make a jumper cable for your fuse box which turns the full headlights on full time, or go to a dealer and maybe have them activate your lights. All jokes aside, Canadian Tire does a pretty decent job of the lights as well. They are also an authorized RIV inspection location who can officially pass your vehicle and declare it "Canadian". DRL's shouldn't cost you more than $150 or you're getting ripped off.
ver simply display change
main menu
scroll to settings
then change MPH to KM
  hebs said:
I need an MPH speedo for the UK. Did you find a replacement ? Ifso , where from ????
Hi I am just about to buy a 2004 boxster with MPH and I live in Germany so need KPH is there any changes other than the clock face that is needed and if not do you have the proceedure, maybe I will swap with you?
Lance
Lance
It's just a clock face change and Ruf can do this for you as they offer both MPH or KM inlays. Not sure how hard it is to perform but my Ruf modified Cayenne started as MPH and was changed to KM by Ruf.
