I've been investigating various possible data loggers for use at autocross events. I'd really like to leverage the car's onboard sensors.
My car has PSM (2001 C2 996 with PSM option).
The PSM monitors wheel speed, engine speed, throttle position, gear selection, lateral acceleration, yaw and steering wheel position. Wow.... That also happens to be the complete set (minus GPS) of data that I would log.
Now, is there any way I can get at this data at a reasonable sampling rate?
Can I hijack the various sensors (split them and use there inputs) perhaps where they go into the PSM unit (if there is such a beast as a box that represents the PSM unit)?
I don't have the shop manuals to look at where the wiring goes. If I did, I'd try to figure out if the various sensors (like the ABS wheel encoders that appear to be located right on the brakes) happen to all go to one convient place.
Any information on the sensors, there workings, the device they go to, the location of the device would be greatly appreciated.
If I do manage to get this project done, I'll be sure to post my results here.
Bart
