It seems to me that easiest source for the center console would be using the phone prep connector and extend the wires down the console (under the carpet). There is both +12 volts switched and unswitched on the phone prep connector.
In the engine compartment?
Well, you've got the alternator right there so there is lots of power close - but I would suggest a fuse for whatever you plan on connecting.
What are thinking about adding in the engine compartment?
Thanks Loren. I'll try the phone prep connector. I have an exhaust that has muffler bypass valves that are controlled by vacuum actuators, activated by a solenoid mounted in the engine bay. Originally I sourced power from a constant source in the engine bay and placed the switch in the glovebox which closes the circuit. I have decided that I do not want to add any more battery drain to the system than there already is. I am using a battery tender when it sits for several days, but I still think that these cars (some of them anyway) have horrible shelf life battery wise! Good thing mine is a daily driver.
