I have 2005 TTs and wondering if wheels from 997 Turbo are compatible with my car. I have seen wheels with following sizes:
235/ 35 19, 19 X 8.5 with 56mm offsets front and 305 30 19, 19x11 with 51mm offsets rear
Thanks in advance.
Thanks in advance.
I have a 2004 TT with 18" wheels. A well known local Porsche performance guy told me that going with 19" would degrade the handling. Check you owner manual to see if 19" an option.
Are those replica wheels or OEM 997TT wheels? They look like OEMs. I believe you only need a 5mm spacer in the rear to make them work... I would use more like 15mm just to make the wheel look more flush to the fender though
  • 6 months later...
