Lorn can you help me on this problem. Car is a 04 C4S around 4,000klms. This morning pushed in clutch turned key nothing. Pulled out key went through same procedure car fired up. Can hear clutch switch working no problem there. Could it be faulty igntion switch. Been working well all day, but if it did it once, chances are it will do it again, and the wrong time and the wrong place. Your thoughts Gene
The two most common issues are the switch on the clutch and the ignition switch. Porsche had some problems with ignition switches in the past. They introduced a new ignition switch in production builds as of September 05, 2003. Starting with VIN numbers:
99 64S 62 0554 USA
99 44S 63 5123 USA
99 74S 65 0736 USA
99 74S 69 2289 USA
Either way this should still be covered by your warranty.
