Hi
I need to replace the headlight washer cover and jet nozzle on my 2003 C2.
Is it a simple DIY or should i book the car in shop? I already ordered the parts from Porsche Parts
Luis Redinha
You can do it with a helper, on your own is difficult.
Pull the telescopic tube out with 2 flat screwdrivers, there is a strong resistance by a build in spring
Let the helper hold the telescopic tube as close as possible to the headlight while you remove the rest of the nozle
Push the new nozle/cover combination on the telescope
Thanks RFM,
Job done
Luis Redinha
