had a free day today so tried to finish an old project....
hopefully wont get to loud and hot in the cabin but i love the way the intake manifold looks with red paint
the pix will show a synopsis of the steps i went through...
tapeing took a while before the paint....cutting the hatch was tedious cause didnt have a template and wasnt sure how big of a hole to cut........the lexan cutting, riveting was easy,.... figuring how to make the lexan hold stabile was the most time consuming.....
if any of you are wanting to do the same....i could give measurements so it goes faster....
if your not a diy'er....check out adrenaline motor sports = http://www.adrenalineautomotive.com
enjoy
ric
engine hatch window
Edited by rxbox
Excellent job, I like the black framing better, it is to bad you cannot see it better with the top down.
I was going to do that with the compartment hatch behind the seats. It would take a lot of spacing or molding of the Lexan or plexiglas to the match the curvature of the hatch. I suggest Lexan due to it's potential to withstand blast.
I wonder... if you were to put another piece of plexiglass on the inside would it deaden the sound, using the air pocket as an insulator.
Still all in all an excellent job by you... man, I hope the maker of the idea doesn't see what kind of money you have saved [DIY] or maybe he should, might wake him up, he seems a little steep...
I wonder how he plans on painting the intakes. Maybe his price is the cost of flying out to each person to paint :D
Edited by mrmickeymouse
Hey tool pants. I noticed you had a picture, with you near a carbon fiber hood on a boxster or a 996.
I have a question for you:
1. Is it considerable lighter.
2. Looks - [is it kind of weird looking] I have a red Boxster and it seems like I have had an accident, and I am using a filler hood, until mine gets fixed.
I would appreciate your opinion.
They say about 20 pounds lighter. I have seen several and the fit was not that great. We spent a long time trying to adjust one on a turbo and still could not get even gaps.
adsach
hey...i went back and paintbrushed the letters on....i have a decal guy that said he could place them on so theres no brush marks but as long as i dont enter a concours...cant notice brush unless 1 foot away....
the second layer of lexan is a good idea.....but that hose pushes up right against it already....i drove around today and it was louder but not to the point where you cant converse with the passenger.......mostly hear detail sounds of the engine....very mild tappets....vacuum in acceleration....which i kinda like(put an hks blowoff valve in the volvo and love when it goes "kwoosh"
i do have a supercharger from tpc coming in may if i play my cards right and that sound just might outdo the bov
i love this car!
When I did my 30k service a few years ago I removed both covers and started the car to see what it sounded like. Good. Then I got the bright idea of driving the car around like that to see what it sounded like and put the top up so that the plastic window would not melt. I got 2 blocks down the street and I melted from all the heat.
The hoses are the protective rubber padding for the shift cables. You can push down on them more if you want.
I drove the car with the top up not down. I was afraid to drive with the top down and the engine lid off as the plastic window would be right above the exposed engine and there is a lot of heat.
