I was removing and replacing the dash strips when I noticed light iside the dash when I removed the flexible plastic cover under the dash. When I removed the glove box, i noticed that the light was on. I tried testing the micro-switch -- it seems to be working ok since the horn doesnt honk when i lock the car with the glove box closed and honks with glove box open.
Not sure what is happening here??? Just removed the bulb for now to stop the battery from draining. I haven't done any electrical mods recently.
Can any one help. THanks in advance
Wierd!! I went to do some more testing on the glove box and it got fixed by itself ?!?!?!
I am not complaining for now :)
Lauren - you can delete the post if you deem appropriate.
