Hi All!
I am looking to do my own clutch replacement as it is that time. I was looking for a DIY on it but did not locate one and wondered if someone knew of a good resource. Also I am needing the part numbers for a couple of parts in the clutch setup. They are apparently a common replacement/upgrade when doing the clutch. I am pretty sure one is the actuating arm? and the other is directly linked to that. The problem is the arm bends and makes depressing the clutch more difficult than normal. TIA!
  • 2 months later...
Hi All!
<_< Although this site is for the RMS replacement, there is a clutch section that might be helpful to you. There are several pages with explicit pics, the link takes you to page 2 (clutch section) Good luck!
http://www.c-speedracing.com/howto/996rms/rms2.php
