:welcome:
Check the fuses - there is one on the main fuse panel B2 (second row from the top - second fuse in from the left. The other fuse is on the back of the radio - and the radio will need to be removed to check/replace that fuse. You will need radio removal keys to remove the radio - most sound shops have these.
