Can anyone explain what the differences are between the 996 OBDII (DME 5.2.2) factory manual and the 986 Boxster OBDII (DME 5.2.2) factory manual?
The 996 manual is on sale at a very reasonable price at Sunset Imports (Board Sponsor) and I was wondering how useful it would be in diagnosing 986 fault codes, etc.
Regards, Maurice.
Only difference that I can think of is the diagram layout of the components section since the (emissions) parts sit in different locations on the Boxster.
Thanks for the info, Loren.
Regards, Maurice.
The DME set-points are different between the 996 and 986 are different as well.
Todd
What are DME "set-points"?
Regards, Maurice.
Things like idle speed, fuel trim, injector pulse length. The standard presets used in diagnosis. If you have the correct setpoint table from the factory service manual, the 996 OBDII manual would be perfectly fine. Just need to be aware of the slight differences between the two.
Todd
Todd
Todd:
Thanks for explanation, it is much appreciated.
Regards, Maurice.
Loren, I spoke with Jeff Clark about these 996 OBD II manuals, and they are pre e-gas only (98-99) and would not be usefull for later models..........................
