just a quick question (not nearly as important as my variocam question...)
i replaced the car battery a little while back and the keyless entry has not worked since. i asked the dealer what i need to do and they told me that i need to buy new keys for $150. is this true? it seems odd that if you replace the battery for approx. $100, you then need to spend another $150 to get your keyless to work.
the battery in the key is fine (i believe.) it flashes continously and brightly when i press the button... also, the trunk button has no effect.
don't they just need to reprogram the key or alarm/keyless system in the car?
thanks
Chris
