Hello
In my 996 the sim card from the pcm popped out and it never come back to position again. I ordered the tray from Becker, and today when trying to remove the PCM, when closing the dents from the side I think I broke the plastic pieces that close it ,as only one side is loose and the other does not move , and the plastic pieces goes 360. Is there any other way to remove the Pcm?
Thank you in advance
:renntech:
The only way to remove the PCM 2 ( by the way from a 2003 996 tt) was to remove the dents , and I had to took the car to workshop , so if anyone else try to remove the PCM be careful not to force the plastic pieces as they will brake making it impossible to remove the unit so easily. In my car (LHD- I dont know if it makes difference) to close the detents ( 2 from each side ) is at the left side up and the right side down and the unit should remove easily . After inserting the Pcm to open the detents is oposite.
Thank you all :renntech: :renntech:
