I have a MY99 996 with the CDR220 head unit. The door speakers sound damaged and I want to replace them. I am looking for 5.25" replacement speakers but need to know two things:
1) What is the current size, namely depth, of the base speakers?
2) What wattage does the CDR220 send to these speakers?
Thanks in advance.
Thanks in advance.
5" nokia
I think 2 ohm.
Do you want another set of factory ones. If so let me know and I will look around to see if I still have them.
C2 Cab,
I have the Bose package in my C2 Cab and they sound "damaged" too. I had them checked out and I'm afraid that that's as good as they're ever going to sound. I am finally going down the slippery slope of an aftermarket system since I just can't stand the way the factory Bose system sounds anymore. If I were going to go through all the trouble of taking the door panel off then I would put a better speaker in there and Dynamat the whole thing. I'm going to pull out everything including the footwell sub, door/dash/rear speakers, and head unit and just start over. It doesn't have to cost an arm and a leg if you don't mind some used amps and do some of the fab yourself.
Realistically, I wouldn't pay a nickel for the factory stuff. I'm just going to be happy not to be embarrassed anymore...
Good luck!
Tonger
Edited by Tonger
C2 Cab,
Good luck!
Tonger
Tonger,
did 99's even come with a footwell sub or any sub at all?
i have the same Hi-Fi option with DSP in my car but there's no subwoofer unless i overlooked something...or it has the worlds greatest stealth device. Can you post a pic up please?
I have the HI-FI package in my 99. Only came with speakers in the doors. The sound is quite bad but not as bad as my first 996 which only had the 4 inch speakers in the dash and rear-side panels.
As I recall, the 99's didn't come with Subs. Only the bose optioned cars did which came later in the 996 series.
Pete
Pete
how big can i go with the doors/dash pods/rear pods without having to do some major work?
5.25" doors?
1" tweeters and 4" drivers for the pods?
Thanks in advance.
5" nokia
I think 2 ohm.
RDS - thanks for the offer, but I think I will upgrade the speakers with a different brand.
Tonger - I had the same thought. I really like the stock look and am not psyched about replacing the head unit as a result. I have a Honda Accord that I drive when the weather is bad and I replaced the stock speakers there. The difference was amazing with a basic stock Honda CD player. The CDR220 is clearly a better radio so I expect to see a significant improvement.
Pete
5.25" doors?
I believe that is correct. IIRC there is a guy Rod at caraudioinovations.com that can put a slightly larger speaker in the door but don't quote me on that. When I was researching options, I remember coming across some work he had done and I believe he put a slightly larger speaker in the doors.
Pete
Check Rennlist for a couple current threads on this. You can fit 6" drivers in the doors with little fuss. 5 1/4's are easier though. The stock speakers and Amplifier are garbage.
Think good options would be:
MB Quart, Morel and Focal, on the lower end of the spectrum (money wise) JL Audio or Boston Acoustics.
There is a rumor that MB Quart was purchased by another company and the newer models are not as good as the older ones.
Just my $0.02.
