Can someone please tell me what these codes mean and how serious they are, I looked them up with a durametric and my warranty is going to expire in 500 miles.. so it'll be a good idea to get anything fixed soon.
9766
Unknown DTC: 9766
17155
Unknown DTC: 17155
32280
Unknown DTC: 32280
10022
Unknown DTC: 10022
P0456
Evaporative Emission System Leak
Detected (very small leak)
P0513
Incorrect Immobilizer Key
P0456 Evaporative Emission System Leak Detected (very small leak)
Most likely a loose gas cap.
P0513 Immobilizer Approval - Signal Implausible
DME or key problem.
None of those other codes come up in any of my books.
In this case - you should have the codes read with a PIWIS.
Can you clear these codes or do any reappear if you did clear them? Are the unknown ones located in the DME or did you find them in a different module like instrument cluster or something?
Unknown is even with PIWIS unknown, clear them and wait for real fault codes. Unknown codes can appears even from outside signals, high tension cables or radio signals.
