The engine bay connector for the O2 sensor has broken off ... the pin. What are my options? Can I try to solder it back? I have read that the lead is a shielded wire ... what do I need to do to fix the connector? It is a tight place to work in ... any suggestions on method?
85 911 Carrera Coupe .. 142,000 miles
Thanks in advance, any help would be much appreciated ... Kiwi01
