Hallo,
I have in my boxster (1998) an old PCM 1 system, 8 bits. number 996 642 122.00
On the screen I read: navigation deactivated.
How can I re-activate my PCM? I have a navi-code and a radio-code. The radio works, the navi don't.
I don't have an original cd anymore , only a copy of the 2000 -1 and 2000-2 version.
Is there a code to re-activate my pcm and do I need an original -cd for the software?
thanks a lot!!!!
WB
Hallo,
thanks a lot!!!!
WB
They all say "deactivated" if you dont have a route live, simply enter an address.
Your problem must be with the copy disk unless you know for sure the system has worked with this disk - I believe the copy protection system will not allow copies to function even though the data has been written to it.
Yes, the system worked for a few monthes with the (copy)disk. Suddenly, it stopped working.
Now, the system gives me:
PCM software IDIS 5.25 (is this correct?
Navig software:--------------
Data base:----------
Than there is : guidance deactivated
I think I have to upload the software ugain with a original cd?
Maybe someone don't need his/here original cd disk anymore because they cannot be upgraded anymore since 2001 I believe?
So unless the disk was taken out and damaged it should work now - unless there is a read fault.
Have you tried a disk head cleaner in the drive unit? Failing that remove the drive and if you are brave open the unit up and try cleaning the laser with a soft brush. - Dust can settle on the laser causing the light to defract - in turn this prevents the laser reading the section of the disk - May be a long shot but what have you got to loose - you have a broken nav and if the cleaning doesnt work you still have a broken Nav but can continue to expolre alternatives.
