Have anyone installed the Sylvania Silverstar clear turn signal bulbs in their Cayenne? My concern is the higher wattage (27W vs stock 21W). I just want to be sure the additional heat doesn't damage anything.
Should be fine... 6 Watts won't make any difference in terms of temperature... To give you an idea, a little nightlight is typically 7 watts... and it barely gets warm.
You may not like the extra light however - might make your turn signal lights overly bright... check it out at night.
I put Silverstar bulbs in when my driver's side turning light went out. They're definitely a few steps brighter; I feel they're overbright. The new bulbs are more powerful than the normal headlights, and it is a moderately annoying effect when you are driving. However, the bulbs are a fairly cheap investment, and it isn't so bad to swap them back out if you don't like it (I did).
