AMG E55 wheels - fit a C4
We would need to know the sizes and offset.
They are likely going to be smaller. For example my AMG CLK55 uses front: 7.5J x 17 offset 37 mm and rear: 8.5J x 17 offset 30 mm
You will want at least a 7.5 x 17 offset 50/55 mm for the front and at least a 9 x 17 offset 55 for rears for your 996 C4 (per Porsche spec).
Loren,
The AMG wheels are 19s. I have been searching online and the bolt pattern is different? Have you put your amg wheels on your 996?
I believe the offset on the wheels are smaller than the (50/55 front, and 55/rears). I think the offsets are somewhere around 30....would it still work? (would spacers work?)
Thanks.
I have not put AMG wheels on my 996.
You would need spacers that are 20 to 25 mm -- if the bolt patterns would match up.
I personally wouldn't recommend any spacer over 17 mm - just too much stress on bearings and bolts.
There are lots of used and low cost wheels for Porsches.
Thanks Loren.
