I am new to this forum and struggling to purchase my first Porsche. The Boxster S was finally delivered after 6 months (officially it is a 2008). Once I realized it was coming in winter I ordered 17-inch Boxster II wheels with winter tires (I like the look), but at the last moment the dealer informed me that they don't fit the S model. I checked wheel/tire sizes on web sites which don't provide a clue as to the problem, but one web site did indicate lack of compatibility. The other set I have is 19-inch Turbo wheels with summer tires, also factory standard. Any ideas if/why the 17-inch wheels are incompatible, and suggestions as to what I should do would be appreciated. There is 50 degree weather in Chicago early next week - the rebellious part of me says probably I could get the car home on the summer tires. But then I'd be stuck.
Thanks, Dan
:welcome:
The Boxster II wheels are approved for use on both the 987 Boxster and Boxster S. Your dealer needs to read TSB 11/07 4440 Approval: Winter Tires,Wheels and Snow Chains -- dated August 17, 2007.
That TSB clearly states that is one of several winter wheels that are approved by Porsche for your car.
Just FYI - All TSBs are available here to Contributing Members. To find out how to become one click here.
:welcome:
That is great news (and fast!). I am most appreciative. I look forward to exploring this site.
Dan
:welcome:
I made a small contribution (to start) but I guess until it registers here I can't view the TSB, so please bear with me.
The service guy looking at the same TSB indicates the 17-inch wheels are not approved for Boxster S. On that assumption... He notes (e.g.) that the console settings for tire pressure only have 18-inch and 19-inch settings, expresses concerns about possible effects on speedometer reading and PSM behavior. I don't care about the speedo; I won't put enough miles on it in the winter that it will matter. Since I can use an external pressure gauge, presumably I can learn to compensate for any discrepancies. I'm more concerned about possible premature, delayed or inappropriate response of PSM (and PASM).
But the thinner and larger aspect ratio 17-inch tires are better for winter. (And, I like the look.) Comments?
Dan
:welcome:
Dan
OK, I can see the TSB now. It is confusing, the 17-inch Boxster II wheels are not flagged but the corresponding tires are.
Dan
