Hi all
Yesterday rear lid did not automatically pulled into the lock. After I have an error message on cluster each time I drive my car.
Does anyone have idea how it could be fixed and what could be the reason of this malfunction.
Regards,
Emil77
Sounds like a bad sensor or control unit. Porsche had a problem back in 2003 with these - but that was fixed.
Best have your dealer/OPC out their PIWIS tester on it.
That was really easy. I disconnected a plug from "auto pulling" module with help of skilled craftsman , connected again - and it started to work!
Edited by emil77
I am having the same issue, the auto-pulling doesn't work and I have to slam the trunk real hard. The car was at the PIWIS tester about 10 days ago and there were no foults (?).
Maybe should I try disconnecting the "auto-pulling" module as well? Where is it located? Has anyone else tried this before? Any other options?
