I just got my PCM2 unit today from UPS. It appears that their are 3 antenna ports on the back. 2 right next to each other(one marked antenna and the other diversity PCM2) and one on the back of the navigation module on the bottom with no marking.
Which cables do I plug into which. Does anyone have a diagram. I would guess the GPS antenna goes into the navigation module, and the FM antenna into the one marked antenna. But what is the diversity PCM2 one for?
Attached is a pic, any ideas...
Edited by CoreyNJ
The connectors should be connected, in the following order: MOST optical connector FIRST; power connector; the speaker connector, folowed by the yellow CAN, green microphone and blue emergency call.
Then connect the antenna leads
Corey, if you don't mind. Where did you order your PCM2 from and how badly were the damages? I'm interested in upgrading my 2003 C2 to the PCM2 unit.
Thanks for the response, but I'm still confused. The refered posting was for a Cayenne, and so some applies.
I still don't know what the diversity antenna is and what the indicated antenna connection is. Atleast I'm now sure about the navigation antenna lead for the gps.
Does my CDR-23 have two antenna inputs, diversity and something plainly marked antenna? I guess I'll pull the radio today and look. I'm just trying to figure out if I ordered everything or do I need more parts for an additional antenna...
Thanks...
Corey...
p.s. I bought the main system used from a fellow boarder who replaced her's(hint-hint) with an alpine unit in her SY 996, with muffler bypass. :)
OK, pulled the cdr-23. It looks like it only has one antenna. So I did a little google search on Diversity, PCM and Porsche. It appears to be a signal enhancement antenna for FM reception integrated into the windscreen. I live in the NY/NJ area and we have awesome reception. So I guess I can't hook that feature up. I guess like retro-fit Litronics on earlier 996's and the factory only auto-leveling, diversity antenna requires ordering PCM from the factory.
Cheers,
Corey...
p.s. I will take pictures when I do the install and post them. First I'm waiting for some parts from suncoast(i.e. gps antenna and cables).
Diversity is additional antenna wires. It is covered in the most recent Boxster and Cayenne tech intro booklets. Check with Loren for a 996.
