im looking to replace my silver b and c pillar trim with the black pieces available from porsche for the black package look. the b pillar is supposed to snap right off so thats easy. but before i order the parts i want to be sure ill be able to swap out the C pillar trim piece. ive heard it may require removal of the window in which case ill have to pass on this mod. does anyone have any insight into the removal of the c pillar? thanks
The outside trim on the C pillar is the most difficult, you have to remove the plastic top trim, the side trims and the windows to do the job good and invisible.
The stealership just did my C pillar and they had to remove the window to do it - first time they didn't get it right and they had to do it a second time. I want to do the exact same thing with my CT but won't for this reason.
Ebay has the carbon fiber stick on covers which at first I thought was cheasy but I have recently seen a CS with them and they looked really good - I still have to think about it.
  • 4 weeks later...
so how much did the dealership charge you for the C pillar? probably any good body shop could do it, maybe thats an alternative
ive already got the parts so either i get that piece on there or ship them back
