The steering wheels for the late 993s and the early boxsters are the same. While i see that with the 993 Rs wheel you give up the airbag will it swap with the boxster steering wheel?
Yep, the 4 spoke Boxster wheel is the same as used on a 993.
If the splines are the same I cannot see why it would not work. One way to find out......
