I understand that Cayenne's don't like led trailer lights. But aha Uhaul sells a part-- P/N 39008 Led Light Trailer Module for $29.95 that "allows VW's, Porsche, and Audi to pull a trailer with led lights - use only with led lights". But this adapter plug transitions from the 7pin round to a 4pin flat trailer connector. What do you use to tow a trailer that has both brakes and led lights and uses a 7pin round connector? Has anyone opened up one of the uhaul adapters to see what magic is inside besides the transition from 7 to 4?
There is a adapter from POLLACK thats a round adapter to a 4 pin i use it to trailer my jetski....Check my posts :)
It also fools the Cayenne into thinking it is hooked up to a trailer with incandescent bulbs. The Cayenne is programmed to expect a trailer that sucks up a certain amount of current to power its bulbs. LEDs use much less current so the Cayenne will incorrectly conclude that one or more bulbs are burned out and will throw a "!" on the display. The U-haul gadget prevents that from happening.
In fact even on a trailer with incandescent bulbs if you have too many or too few bulbs and depending on the wattage of the bulbs installed the Cayenne may or may not throw a "!" on the display.
