My 73 911 T has a lean spot in the lower rpm range causing it to fire back through the intake, buck and snort, so to speak, but catches ahold about 3500 rpm and smooths up. A local mechanic tells me I have a throttle valve problem where it is not richening up in the lower rpm range. I could use some help on where to look for this part and if it is maybe rebuildable.
CIS or Mechanical?
CIS or Mechanical?
Mechanical (Bosch)
CIS or Mechanical?
Mechanical (Bosch)
My CIS had a similar problem, but it turned out to be a faulty "pop-off" valve vs. "throttle valve".
Have you looked over at Rennlist.com at their forums? Great source of info?
