I have a 2001 base 986 with manual transmission with a 2.7 liter that has spun a rod bearing and needs a new engine. I have been offered a 3.2 liter "S" engine. Is this simply a plug and play? If not plug and play, what else has to change and is the change difficult or pricey? While it would be nice to do a 3.6 conversion, I very simply don't have the funds for that.
Mike
Mike
The only Difference is maybe the pressure plate for a 5 speed vs a 6 speed.
If the Boxster S engine is from a MY03 or newer Boxster then it has VarioCam Plus and would require a DME change and you may need to use the fuel lines and intake from your old engine (due to changed in the fuel circuit (returnless fuel system)).
Good point
The 'S' is from an 02. What is involved in:
"The only Difference is maybe the pressure plate for a 5 speed vs a 6 speed"
What does that cost?? Sorry for the simple question, but I"m not mechanically inclined. :P
Mike
Good point
Mike
Good point
$200+/-
Mike
Good point
$200+/-
Thanks, so I could use the same transmission thats in my base 2.7, just change the "pressure plate"?
Mike
Professor Holyoak can usually figure out these engine swap questions.
I think a 2002 3.2 swap into a 2001 2.7 would be interesting. I would think your 5 speed transmission would bolt up to the 3.2 engine, no clue what clutch parts would be used. As far as the horse power difference between a 2.7 and 3.2 it is not much, when compared to 2.5 owners who put in the 3.4 from a 996 and keep the 5 speed Boxster transmission.
VarioCamPlus is not an issue, since the 986 Boxster never had it, only VarioCam
Go for the 996 engine. I did the 3.4 and spent about the same as I would have to simply replace the motor with the same 2.7 I had in there.
-Michael
Savowood,
I've already got a 3.2 on the way. I wanted it to be as simple as possible.
Mike
-Michael
