I have an 06 997 C2S with black dials for both the instrument cluster and sports chrono. Are you interested in a swap if we can figure out how to get them out carefully?
The 997 font is a Porsche copyright , so only original gauge faces will be the perfect match. There are companies that offer replacement gauge faces such as REAP automotive, but you will have to accept the earlier 996 font. Changing the faces is not recommended for DIY , since the cluster is quite fragile and incorrect placement of the face may result in a speedo error.
