I have a 99 C4 and the gas pedal was sticking a bit at the very beginning of its movement. I followed the directions here to fit it: http://forums.rennlist.com/rennforums/show...amp;postcount=9 but I wanted to add some clarifications. My pedal was held down by two plastic tabs as well as the screw, it took a good pull to break it loose but the tabs don't seem to be the type that would break. My pedal also had a few openings on the bottom so I sprayed white lithium grease in that way instead of pulling back the boot. After putting it all back together it seems to work great, no more rough accelerations.
