This is for a Cayman S, however I thought this the best forum to pose this query. I've found information that the #1 engine pulse wire is E-6 on the DME for 996/997 cars. On those cars the E plug is the most outboard plug, however the DME is mounted vertically on the driver's left rear firewall on the Cayman, with the plug side of the DME facing towards the center of the car. I'm not sure what the orientation is for the 996/997 DME to translate the information.
My question is which plug is plug E, and how best to locate wire E-6. Thanks, and Happy Holiday
I think you want D17 on the DME (TN-signal) - that is what was used for all the older cars.
Thanks Loren. Before I saw your post I tapped E-6, plug E is at the TOP of the DME for a Cayman. It became more obvious as I examined the plugs. After setting the "number of cylinders" in Traqview to 1 and not 6, the RPM reads correctly.
