My airbag light came on. I had the code read, and the problem isn't the seatbelt - rather it's something in the steering column.
Is there a TSB or DIY on this? or should I just leave it to the pros this time?
Thanks in advance.
-td
Most often it is the trigging spring in the steering wheel.
Do you know the fault code number?
Sorry, Loren, I didn't ask for the specific code. After some contemplation - I'm going to let the Ruf guys fix it. I'm a little nervous about fiddling with the airbag system.
Thanks for your help!
-tom
-tom
Tom:
If they fix it, could you post the fault number and the fix they implemented? It would help any members in the future, as this topic comes up fairly frequently.
Regards, Maurice.
