What is the largest tire I can fit on a 10inch wheel?
Probably a 320/90R54.
At nominal 78.0" in overall diameter and 12.6" wide, for an R-2 designation (cane and rice tread depth), this rear tractor tire can carry up to 7600 lbs at 52 psi.
--Brian
Keep in mind the larger the sidewall the worse the handling. So when you go big you better go lower number on the profile. So if you currently have a 40 profile going larger you may have to go to a 30 or smaller.
Just bought some iForged 19x8, 19x10. I know a 285/30/19 and 285/35/19 is possible, but what about a 305/30/19?
From memory, it is not recommended to fit a 305/30R19 to a 10" rim; I think 295 was the max. I will check the relevant tire standards in the morning to make sure. If the rim is too narrow, the sidewalls and tread arc are inappropriately distorted and the air cavity created by the tire and wheel is too small. --Brian
Confirmed: a 305/30R19 should go on a 10.5" wide rim at a minimum; 11.0" is nominal recommended for this size.
Widest 19" 30 series tire recommended for a 10" wide rim is a 295.
--Brian
