I have a 2001 Boxster. When I use the fog lights my left turn signal does not function. There are no other symptoms that I can see. Is there a relay or something that needs replacing?
are you sure it's only when you use the fogs? Or does it happen when you use the headlights or parking lights too? Is so, then your side indicator bulb is probably burnt out. Pull out the side marker and check the bulb or swap the bulb w/ the other side to test.
