My steering wheel squeaks when I turn it, it sounds like it is coming from somewhere in the dash. Could I be low on PS fluid?
If the noise is in/near the steering wheel then it is not likely fluid. The fluid is easy enough to check (see your owners manual).
If it is in the steering wheel then chances are the rubber bushing are worn. There are a number of threads here about that and horn problems.
You pretty much need to remove the steering wheel and have a look (using precautions for the air bag).
