After being away from the joys of Boxster ownership for a couple of years, I took the plunge again last month with a slightly used 2003 "S" and experienced something I didn't recall from my last Boxster: condensation on the inside of the rear trunk lid over the coolant cap. "Faulty cap" immediately came to mind, was confirmed by dealer, cap replaced . . . but now I still have a persistent thin film of moisture (as opposed to droplets) in the same spot. The car is not overheating and the coolant level is mid-point between min and max. Is this normal? Does the cap vent vapor to accomodate expansion of the coolant?
You should not have condensation above the cap. The newest style cap ends in 01 and I trust that is what was put on. Is the cap screwed on properly? If so, all I can think of is it might be another bad cap.
