Hi guys, i'm searching for a sotware with the relative ODB cable to read the Porsche ECU.
I know that there is a tuner selling this article but i can't remember its name, can somebody help me with the link to their website ?
Thank u
And do you know if is there the possibility to buy a software that allows me not only to read the ECU but also to modify its main values ?
What i mean is if is available on the market a program/sotware to modify the ECU values depending on my daily needs ?
Thnks in advance.
Other than resetting codes (which the Durametric can do) it can not change factory settings.
You would would need a PST2 or PIWIS tester and then you could only change programs that are supplied by Porsche - not individual ECU values.
And, these machine are several thousand dollars.
