rain sensor / autodim mirror retrofit ?
The rain sensor is part of the windshield and this would need to be replaced.
With all due respect - no it is not part of the windshield. It is attached by a self-adhesive.
Porsche published a group of TSBs for the 996 on this retrofit - but the 997 is different I suspect you will need to add some wiring for all the parts then have them turned on with a PIWIS tester.
It can probably be done but I have yet o see anything published from Porsche - so you would need to have a look at the wiring diagrams and make sure you get all the right parts. BTW the rain sensor part is different depending on whether it is a coupe or cab AND whether or not you have the dimming mirrors.
I find the rain sensor a really worthwhile addition in the climate over here. The one that Porsche offer as a retrofit kit is made by Xanonex in Germany, and they don't produce a unit compatible with the 987/997. As Loren says, I think it would be a whole lot more difficult than the plug-and-play unit for the 996.
thanks for the replies;
I did retrofit the rain sensor to my 996 a couple of years ago - as you say Richard in our climate it is a real advantage. Was quite easy to install too.
I spoke with an OPC yesterday who confirmed that Porsche do not sell a retrofit kit for the 997.
But, as I am stubborn, I'll see if I can find a way around it !
No, it's not a deal breaker - I was spoilt as my previous (now deceased) 997s had virtually every option in the book !
If anyone comes up with a bright idea on this please let me know !
David
The rain sensor is shown on the PET with what looks like a wiring harness and plug. There isn't a special wiper switch for the rain sensor option (I268) so my guess is that it might be "simply" a case of fitting the sensor and getting it programmed with a PIWIS. This is how it is done with the 987/997 cruise retrofit kit. Like I say, it's a guess.
The sensor is about £150+VAT, BTW.
tmp.pdf
Edited by Richard Hamilton
