I recently purchased a 2002 996 TT Tip. I have been having an intermittent problem that the dealer (Paul Miller Porsche) is unable to identify. The problem is intermittent and seems to act up if the car has been sitting for a couple of days.
When I am at highway speed in automatic mode (usually 5th gear), and I drive on an offramp and decelerate the cars does not downshift appropriately, and when I accelerate again there is a metal rattle that comes from the rear of the car. The rattle sounds like clanking aluminum drum sticks together. This only happens occasionally, and never when the dealer has the car. The rattle will stop if I manually downshift the car into the correct gear.
The car also seems to have a persistent low grade vibration, that is worse on cold starts.
The dealer says that there is nothing wrong with the car. The car has been aligned twice.
Has anyone ever heard of this? Are 2002 Tips known to have problems?
Please help!!!!!!
How many miles on the car?
What has the dealer done to the Tip so far?
Changed the fluid?
Read the diagnostic codes?
Any parts replaced?
Reprogrammed the Tip controller?
32K on the car.
Dealer has done nothing to the tranny so far. They claim that they can find nothing wrong???????
Changed the fluid?
Any parts replaced?
Well, they should top up the fluid to start. Then they should run the full PST2 or PIWIS diagnostics.
Check the Tip program version - update it if needed.
Thanks for the input!!
I have a 2001 996TT that does a couple of things:
1) when accelerating in a higher gear [manual shift mode] there is a rattling sound coming from the rear of the car [most noticeable in close confines]. It sounds more like a loose heat shield or panel.
2) since buying the car I have noticed that the auto torque converter lockup 'hunts' more often, unlocking and locking when your having a quiet moment driving the car, you'd swear that the transmission has shifted but it hasn't just the tranny has unlocked and then locked.
The car has been into Porsche and they tell me there is a TSB out on a similar auto problem which causes noises and lockup. They say it is symptomatic of driving the car calmly, however I drive quite hard so not sure about that comment. Anyways they are replacing the transmission ECU under warranty.
Scott
  • 5 weeks later...
Following up on the tip problem, OPC have changed out the tip control module which has improved changes and tip lockup and unlock.
However the tip still produces a 'rattling' sound from the front of the tranny when running in third gear with little engine load, like when your loafing in the traffic in third. So the story goes they are replacing the tranny which includes transaxle and tranfer case under warranty next week.
Make sure you work your OPC to ensure the problem is resolved.
Scott
