I had the imfamous PCM Eats CD Syndrome. I took the car to my dealer and it has been replaced. Now the CD player will not recognize my existing MP3 CDs. Is there a possibility that the CD-Player in this PCM head unit is of an older generation?
Perhaps there's a change I can make to the way I create CDs?
Obviously, I'd be quite disappointed if I'm not going to be able to play MP3 CDs anymore.
I am hoping that there's a change or setting I'm missing rather than what I suspect: PCNA / my dealer sent the wrong / old PCM head unit over.
I don't have that much confidence as the techs wiped my stored locations after I told them to back that info up. They said it wasn't possible.
Thanks in advance,
STS
The units fitted with the MP3 compatable drive are level B software or above. This function should work straight out of the box. It could be an older generation refurbished unit has been installed instead , which has been upgraded to level B , but does not have MP3 compatability. You should be running version 3.3 software if its a new unit and MP3 capable. I don't think the older units can be upgraded beyond level 3 software , though i'm not absolutely certain on this. Press main and trip buttons to get info on software level.
Berty987,
Thanks so much for your reply.
I just checked and my software is
1.0
PCM info is:
Target: /
Actual 04202JD1 / 3004
Entered: Yes
Found: Yes
System Software
Target: /
Actual: 04113AD1 / 1104
Entered: Yes
Found: Yes
In this menu the top three items (System , PCM , Amplifier) all have Warning Triangles listed. The Nav item has a check mark.
Does this confirm that the PCM was installed improperly or that the software revision is old / it's a refurbished unit?
Thanks again,
STS
  • 4 weeks later...
Berty987,
1.0
PCM info is:
Target: /
Entered: Yes
Found: Yes
System Software
Target: /
Entered: Yes
Found: Yes
Thanks again,
STS
This suggests that the PCM that has been fitted is an early generation unit , the software revision being level 1 and the PCM software being the lower range of numbers. The updated PCM software is 05 rather than 04 prefix, and the software level for your age of car should be at least version 3.1 if not 3.3 (rather than 1.0 as you have at the moment). Since your car is a later version , this explains why the system , amplifier and PCM all have warning triangles , as the existing hardware in the car does not match the software in the PCM. The Porsche agent should have checked this after refitting the new unit and updated the PCM to level B to match the navigation and amplifier hardware. They should then have cleared all the fault codes from the system. Certainly it sounds suspect that the PCM you have been supplied is not Mp3 compatable as was your previous unit.
Edited by berty987
