Hey all,
Does anyone know if the 2.0 PCM has a backlight for the LCD? Mine has went very, very dim, but with sunlight on it you can still read it and it works perfectly. Just wondering if there is a backlight that may have blown?? Unfortunately it is outta warranty and wouldn't mind getting it back up and running. Sent an email to Becker but no reply as of yet.
Cheers
Parajed
Does anyone know anything about this? I am trying to figure out if it has a backlight or not. Also looking for a part # so I can just search for a replacement LCD screen for it. I can faintly see the screen, it still works, just very, very dim!!
Cheers
Cheers
never saw such a thing check your day/nite mode and contrast/brightness
Wish it was that easy!!! Contrast and brightness are max. No difference inbetween modes. Thanks though!!!
I has same trouble only once before. control unit for backlit lamp was broken, electronic workshop fix problem in 2 hours. unlucky, no original spare parts to repair PCM.
