I am installing a "used" MOST PCMII into my 03 carrera with Hi-Fi. The unit came out of an 03' which I think has Bose.
I have the GPS Antenna, trim pieces and GPS extension cables.
My only concern is the lack of documentation on the install, which I will be doing myself except for the programming of the unit.
I am not confident the dealer knows which options to program/set. I do know they will need to set it to recognize my vin number or the PCM will shut down due to the anti-theft system.
What other codes need to be configured to have an operation unit. Do they set it to non-bose or is the PCM smart enough?
Any help would be appreciated with the install or with the programming.
thanks in advance
Corey
There is supposed to be a TSB for PCM 2 upgrades floating around but neither I nor any of the dealer techs I know have a copy. If your dealer follows the procedures in the Service Manual they should know what to set using the PST2. It is basically check boxes for the options on your car.
Thanks Loren,
What exactly should I tell them to reference in the Service Manual? Is there a section title. I like to go in knowing what I'm talking about since this will be their first PCM-II retrofit.
BTW: I will photo document this install and post it here and on PPBB when I'm done.
Corey...
I have a 996, it comes with the OBC/Trip Computer standard.
On the boxster it's an option. I used to have an 01 boxster, so here the deal with boxsters and retro-fit OBC: On pre-02 boxters you need to add the stalk and enable the display with the PST2. On 02 and higher the actual LCD display changes as well, it's a colour multi-function display when you have the OBC from the factory.
Cheers,
Corey
