Can anyone post or send me a scan of the wiring diagram for a 997 or Cayman
ignition switch?
I'm looking for the pinout for the 16-pin connector on the ignition key/lock
module 997.618.161.01.
Bill
Here you go...
I hope you are not trying to put this in an older car because the 9x7 series uses a completely different circuit - including a PAS (Porsche Access System) controller.
Wow, that was quick, thanks.
No, not trying to put one in an older car, just part of my on-going
reverse-engineering project(s). I got one from a junkyard to get
a hold of the an RFID transducer coil.
Do you happen to know if the RFID capsules in the 997 keys work with
the 996 electronics? They physically look different.
Bill
  • 16 years later...
I am having trouble with removing the key. New car battery and ignition switch module did not help. Wondering if anything in the wiring harness could be faulty...........
