Does anyone know if the compression ratio for the 997 3.8 X 51 changes from the standard 3.8's compression of 11.8 to 1.
VMAN
  • 3 months later...
VMAN
No, it stays the same. I had mine done as a retrofit and there's no change in compression ratio. Also, unlike the X51 kit for the 996, there are no new camshafts either, as the original camshafts the car has get reused.
