HI,
am having problems with the (pcm) cd player, sat nav and phone not powering on at all..
any help and advice would be much appreciated
car is a 2002 996 turbo.
thanks.
Have you checked fuse E1 and E5?
I think there might also be a fuse on the back of the unit too.
hi,
thanks loren.
i checked the the fuse e1 and e5 both are fine.
how do i check the fuse on the back on the unit i can see any place where to insert keys to remove the unit.
its a 2002 996 turbo with pcm n phone kit and sat nav.
1. Unclip the switch covers from below and let them dangle from the electric leads.
2. Press together both spring clamps on the display and operator control unit and carefully pull out.
3. Disconnect electrical plug connections from the display and operator control unit.
