My cruise does not work --- light come on etc --- but won't engage. Have read it could be my brake switch and yes I checked the other fuses.
Where is the brake switch ????? I have looked above brake area at the relays --- but marked brake. I need help.
Also do I need to add any antifreeze coolent or test for winter? Do I need to drain and refill. Where do you drain?????
Thanks, Chuck
The brake light switch is on the brake pedal.
If the system integrity has been kept intact then you should be fine. The coolant is "Lifetime" coolant per Porsche.
Do not mix coolants with the Porsche coolant.
