Hi All,
As the title explains already, I have not been able to find my switched 12V in the cayenne tt (2003). The car is packed with all nice electronic gadgets, but I am not able to find 12V which goes parralel with the ignition (on=on, off=off).
Perhaps I am doing something wrong. I have measured nearly all fuses. Earth (+) is coming directly from the battery and the power (-) is being measured from every fuse. Could it perhaps be that all the fuses are 'hot' and that the earth (+) is swithed with the ignition??
Does somebody perhaps have an idea which wire beneath the driver seat (spagetty next to the battery) is switched 12V?
Frank
I used the driver side fuse box. The first 2 coloms are switched (means first from the drivers position, not from the hood position). Do not exactly know the number I used, but if needed I can look it up.
Frank.
