I recently filled the windshield washer tank with distilled water. The dash light came on.
What did I do wrong? 1999 Boxster.
Bob
Edited by wang
could be a dirty sensor - could be you have a leak?
Hi Loren,
Thank you for your help. I put two quarts of distilled water in the tank. No leaks. nothing on the carpet inside or under the car.
I use distilled water instead of chemical laced washer fluid. At 70 MPH I'm concerned about the top and "bleach marks."
A dirty sensor? Where and how? Could the sensor be reading the difference between washer fluid and water?
Bob
Bob, why distilled water? Are you sure you added it to the right place?
I use distilled water because I'm concerned about chemicals in the washer fluid at 70 MPH. I do not want bleach marks on the top.
I put the water in the correct hole and screwed the cap on. In July it will be 10 years old. Maybe I should break down and see a dealer.
Or walk over to White's Mortuary and lay down. Thanks for your help.
Bob
Please disregard what I mentioned earlier -- I think my wife dropped a stupid pill in my cereal this morning -- my whold day at work has been a disaster also.
Sorry for the bogus info.....
Regards,
paul...
Edited by paulv
My espresso maker advises not to use distilled water because the sensor operates on
the electrical conductivity, and indeed I sometimes have seen it indicate "empy" when
full. I throw in a cup of tap water, and hey, presto! it is off and running. Is there a
chance Porsche uses a similar sensor?
  • 2 months later...
I have more information regarding the ww dash light problem. I crashed the car in July and got it
back in August. I was doing pre winter maintenance in November and did not think the accident
had an effect on the ww dash light. When I picked up the car in August I checked lights, doors,
top movement, trunk levers, etc. I did not check the ww fluid level. I filled the reservoir spout
with 2 quarts of water and the light came on. Took off for Mexico, San Diego, Palm Springs, and
Las Vegas for 2 months. Returned home and after the local temp got above 50 I looked at the problem
again. I noticed the hoses and electric connections go through the side next to the drivers front
fender. I drained the ww tank by holding the lever. The tank was empty - no water hitting the ww.
I heard the pump laboring. Let go of the activation lever and the dash light went out. I put one quart
of water in the tank. Started the car and the dash light came on. Drained the tank again and the light
went out. My questions: Does one remove the plastic type composite material shroud that forms the
wheel well to gain access to the ww reservoir tank? Or does one have to remove the fender? I think the
repair shop will deny they are at fault. Also is it possible the make the electrical connection backwards
so that the polarity is reversed. Empty tank = light out. Full tank = light on.
Thanks for your help,
Bob
