I just want to thank both Toolpants as well as Henry for working out a deal to help host the soundbits. I was able to find some space myself to post them so below are the links to all three files. There is a stock 2003/2004 Boxster S exhaust sound file as well as two files that have what the new Porsche Sport Exhaust sounds like. All files were made with the microphone at the same distance from the exhaust pipe. I only have 1900 miles on the car and exhaust and it is still getting louder and more agressive as it continues to break in.
2004 Boxster S - Standard Exhaust
2004 Boxster S - Factory Sport Exhaust Option 1
2004 Boxster S - Factory Sport Exhaust Option 2
Please let me know if these files don't work, this is the first time I have hosted anything myself. Enjoy!
A4EP
Great sound clips. Can you clarify option 1 vs option 2? This confirms my pitiful S exhaust sound...
I guess I labeled it incorrectly, there is no difference between "option 1" and "option 2" It is supposed to be "Porsche Sport Exhaust Option" Then the two different files. One is of the car starting and the other is just a little more reving. That is all
A4EP
Sounds really good, but is it only adaptable to a 2003 + Boxster or will it retrofit to any year and model.
Kind of rice burner like, off of one those V-Tec motors with a 3 inch exhaust. :rolleyes:
That sounds awesome.. I have to ask, have you ever heard the GHL (I think you mentioned that you had) and what did you think of that?
Also, any resonance at any range?
Thanks for the sounds clips! :D
I have head the GHL and I really like it but I would hate to have the resonance with it. I have also had random comments from people in my parking garage where the other Boxster S has the GHL that mine sounds meaner and better. This is from non Porsche enthusists. Take it for what it is worth.
I have recorded some new sound files and put them on my pathetic attempt of a webpage :) They are the exhaust under acceleration. Click the link below to get a list and description of each:
A4EP's 2004 Porsche Factory Sport Exhaust Information Page
This is indeed a more powerful throatier sound.
It might be more than I want in my residential neighborhood in the wee hours of the morning.
Are these sound files with the bypass valve rigged open?
, or
is this 'stock' bypass valve operation?
also, some folks have had good luck recording wheel and engine noise by mounting the microphone inside the trunk.
, or
Totally stock. Only thing is the cutout between 25-45 mph that is standard with the electronics was removed so it can only be shut off manually by depressing the switch on the dashboard.
A4EP
Can you record with the sound "on" and "off" via the switch position? By the way, thanks for the effort here, that is really helpful!
That is how all the sound files are recorded. There is a "Standard Exhaust" version of each example and a "Porsche Sport Exhaust" version of each sample.
A4EP
