How do you remove the head light nozzle that protrudes through the bumper? Is it just a case of tugging?
It's mounted from within the bumper so you will need to whip that off first.
You're not tinkering already are you? :huh:
Pop
Pop
The washer jet is mounted inside the bumper, however I just want to remove the silver nozzle head not the complete washer system.
ps. Yes I have been tinkering..... I have set of deviating washer nozzles on the way from Eric at Bumperplugs.
Pop
Well the unit pops up and out and then the nozzle itself is just unclipped. But be careful on exerting too much pressure.
Pop
